stembridge
The Middle South
Pentastar 3.6
You must be registered for see images attach
Got my new tires and wheels.
17”x8” with Duratrac 295/70/17.
Got super lucky with only barely 1/2”
Space before it hits the UCA.
No spacers? And are those OE DG55 wheels (17x8+18, not OEM Rebel)? That's what I put on my truck, but shod with the Geolandar ATs it came with (265/70R17). I added 1.5" spacers in an effort to get the tires flush with the wheel flares, but the narrow tires still don't look "right." I was actually pricing out a different wheel/tire setup, but after seeing yours (which looks perfect to my eye), I'm thinking all I need to do is go to a 295/70R17 tire - if the track of the Warlock is the same as the Tradesman, I think that will get me the look I want.
EDIT - saw your post in another thread that answered my questions - thx.
Love your truck!
es
Socalramfan
Huntington Beach
2011 Big Horn
I already installed the husky floor mats, black 3rd brake light, sub and amp. Today im installing all 6 speakers in the truck and pedal kit, I ordered new LED headlight bulbs, cabin filter kit, led license plate lights, now to order a 5' turbo back and 3" lift.
Looking forward to seeing the progress. You've got something great too start with as it is :waytogo:
Treburkulosis
Replaced this since mine decided it wanted a divorce from my bumper yesterday morning.
HEMI_Finn
U.S. ARMY Veteran
N.E. Ohio
Upgraded the rear control arms, upper and lower, to fixed length Core 4x4 control arms. The oem arms were to the point that when hitting a bump or even going across railroad tracks it would feel like an angry god would slap the *** end of the truck sideways! At higher speeds it was downright scary. The Core's made a night and day difference.
Socalramfan
Huntington Beach
2011 Big Horn
lets see :waytogo:
Htsderek
Central Coast of California
EcoDiesel
Washed it, filled the tank, and cleaned the MAP sensor.
The truck's at 77k miles without a tune (I would get the GDE if I could but, California!), there were no codes but the sensor was thoroughly caked over.
Also took the tail gate off and cleaned/re-greased the pivot points, and put the fuzzy side of some Velcro behind the right side bushing to push the tail gate back to the center. The tail gate was close enough to the right side of the bed to chip and wear through the paint. I've got to go to the dealer and pick up some touch up paint next.
I'm going to try and make time in the next few weeks to pull the EGR tube off and clean it out too.
FamilyWagon
NoVA
Got 1 of my side rails on, what a pain in the rear. I’ll do the other tomorrow, only got one pic bc it got dark.
YeeterLee
Minnesota
5.7L
Love your truck!
es
Yes sir youre correct, totally flush fit with my factory fender flares. If i wanted to get a more aggressive stance/look, i'd get 1' spacers; but im very content with the fitment. Also, yeah double check that track compared with Warlocks since they have factory 1'' lifts.
should be good.
YeeterLee
Minnesota
5.7L
Nice, .51" taller and .31" wider than the stock 285's. Any speedo issues with those?
None at all. any bigger like 35s/12.5'' or 305 tires, then youll run into speedo issues if im correct.
feel free to jump in and correct me.
stembridge
The Middle South
Pentastar 3.6
According to an online calculator, 295/70R17 tires are 42mm taller than the Yokohama Geolandar AT LT265/70R17E tires my truck came with, which means my speedo will indicate ~57mph when I'm actually doing 60mph. I'll use AlfaOBD to adjust.
Pretty much based on your photo ;), I went ahead and ordered a set of Yokohama Geolandar X-ATs yesterday - had them on my previous truck and liked them a lot.
BTW, thank you for your service, sir! My truck wears the front plate with submariner dolphins that was on my Dad's truck before he passed in 2018. He qualified on the SS-477 Congor and was an E3 Machinist Mate on the SSR-312 Burrfish (radar picket sub), in charge of the two Fairbanks-Morse 9-cylinder, opposed-piston 'rock crusher' diesels in the forward engine room (he had some good sea stories!).
es
