What do I do????
bear run
bear run
Georgia
That’s fantastic!!!
When you’re ready to pull the trigger allow @Nick@GotExhaust to give you a quote you never know his prices may be good enough to not have to wait on the coil overs.
He would have to be lower than what bds quotes from the factory than If that's possible. The kit I priced on the site is 3800 without the coilovers. I'm also kind of inclined to get the kit through the shop that is putting it together, as they have already spent a good amount of time shooting the breeze with me and answering an annoying level of questions that I have. I mean if @Nick can get it considerably cheaper and the shop won't match I guess that's a different story. But the kit is the 6" bds with every upgraded option other than the coilovers.
Nick@GotExhaust
Preferred Vendor
SC
I recommend going with Zone, just as good and much cheaper. We can then get you setup 2.5" Fox Coil overs. Let me know if you would like a quote. Just send me a message
JD522
VA
Can someone explain how you get a 5/3 Zone lift as stated earlier in this thread? I have 2.75" of rake right now. So, a 6/3 will leave it nose high, which I definitely don't want. I assumed I had to get a 4/3" with 5100s up front to add the extra front height. I assume I will bet getting 5100s regardless. Would it be better to get the 5/3 from Zone and leave the 5100s at 0 adjustment?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Fox/BDS coil overs are fully adjustable roughly anywhere from 4”-7”
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@Nick@GotExhaust can set you up with the coil overs. Is the front higher than the rear?
JD522
VA
No. The rear is higher than the front. I don't know much about suspension or lifts. If I understand correctly, the Zone lift is a spacer above the strut. So to get a Zone 5" lift do you just use the adjustable coil over instead of the spacer? If so, is this better than using the Zone lift spacer + Bilstein 5100s - other than the coil over being superior to the 5100?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Sorry I read wrong I thought you had the zone lift already. Coil overs are a far better way to lift anything. However they usually cost the same as the entire lift so they are not for everyone. Another way to achieve 5-3 is to set your billsteins at the stock height and not use the preload spacer included in the kit. Zones strut top spacers will net you 5” in the front and a 3” rear coil will leave you with a rake of 3/4”
JD522
VA
Is that a better way to lift than using the 4/3 with Bilsteins extended a bit?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
It’s a 4/2 lift out of the box unless you mix and match.
We can help you much better on here if you’re more specific in what you would like to have. If you have a wheel and tire combo you want to clear, the look you’re going for etc. Everyone has their own budget to contend with so we can dial in a kit with your needs and budget. The broad questions tend to get other members confused and mislead
JD522
VA
I will start a new thread so I don't hijack this one any further. I just saw mention of a 5/3 Zone lift and was curious.
