What funky things does yours Ram do when its cold
16Ram4x4
Missouri
In really cold weather I can hear the active grill shutter making noise while closing on the first start after setting all night
B
Big Daddy
I know its mine has gremlins. But she's almost 12 with 300,000 miles, I call it personality.
njjeff201
Sparta, NJ
5.7 E Torque Hemi
Get yourself a battery cable puller & cleaner... clean the battery posts & cables. Just in case there's a severe voltage drop when starting. Maybe a battery test like a Load Test & Cell test. Let's be 100% sure your battery is good. Basics first!
Mike Works
Virginia
Shifting from 1st to 2nd gear is a jerking motion when cold.
mtwofeathers
Kingman Arizona
Diesel 5.9
My seat and steering wheel get too hot to handle or sit! Oh and the mirrors for some reason start melting ice on them. Very strange thing.
Chuck962500
Idles on seven till warm then no issues .throws a P300 multiple misfire .not the wires or plugs .since i gutted the cat tries to lean at idle.but once warm no issues .id check your griunds..20210215_171631.jpg
jejb
NW Arkansas
My notchy steering feel is more pronounced when the truck is cold. The steering gear box is being replaced this week under warranty, so hopefully that will cure it.
SharkByte
Pahrump, NV
When the temp is below about 30 degrees Fahrenheit the dash lights on my 2016 1500 Sport flicker on and off if I turn the brightness down. Crank the brightness up and they even out and work just fine. They only do it when its stupid cold. I checked every ground I could find and everything is tight. Haven't had time to look into it more than that though.
full
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Other then making my Johnson shrink till it warms up :O
and a little lag in shifting for a couple minutes all is fine, Very minor lag in shifting...
B
Big Daddy
This has been going on for almost 7 years. battery and alternator are good...
