Peter Kerr
Bridgestone Dueler H/L. Most miles I’ve got from a tire. Mine are 20’s
My choice would be BF Goodrich K02. I have used them both on my Ram and Grand Cherokee. They handle well and last a long time.I need new tires on my 2012 Ram. I been buying Goodyear sra’s since i bought it in 2013 but only get 2 yrs/20,000 miles out of them. What tire would you guys suggest?
I lost about 1-2 mpg. Ride is good as is wet & snow performance.How did/do the Coopers affect your MPG, if any, assuming you are running stock size...?
I think this is an important question. If I seldom tow, drive mostly highway miles, never peel out, and never drive on gravel roads, I'll get 40,000 miles out of a set of SRA's. If you tow 50% of the time and spend the other 50% on gravel roads, you may get half the mileage out of them that I did.How do you use your truck?
Off road, tow, haul?
I have the Goodyear ultraterrain it's a Discount tire exclusive but so far so good. Alot better then the sra's in my opinion.
Not too many probably about 1k but they are great in the Las Vegas desert and do well in the little snow we have around us in the mountains. Smooth as silk in the highway. i know i do not have alot on them but way better then sra's. I went with the 275/65r20 on the stock wheels.I am seriously considering getting those for my truck. How may miles on them so far?
Everything is a compromise.
Softer rubber sticks better, but harder rubber lasts longer.
Low profile, wide tires give better traction & handling, but in snow you want tall & skinny.
Tread patterns that are made to excel off-road will not outperform street tires when both are on the street.
Anything you gain in one category often costs you in other categories. You need to pick what options are most important to you and then base your decision on what fits best for that scenario.
It's true that expensive tires often last longer, but even then, that isn't always the best choice. My truck is a 2017 and only has 30,000 miles on it so far. Now it would be foolish for me I spend a fortune to get tires that will last 70,000 miles. Why? I'd have to keep them on there for 9 years before I reached that mileage! I don't want 9 year old tires on my truck! Now back when I was driving 40,000 miles a year, I'd pick treadwear as the most important factor.
Hope that makes sense.
