MO_CPA
- Sep 14, 2018
- 56
- 54
- Location
- Springfield, Missouri
- 2019
- 6.7L
Block off plate for when you take the tail gate off. Keeps the plugs from getting corroded.
The block heater itself is right by the oil filter, start looking there. If you don't have a cord, Geno's Garage sells them cheaper than the OEM and their probably made by the same manufacturer.Thank you! Now if I can find where my engine block heater cord is.
Thanks! Do they Normally come with a cord also? I have a time low for mine in the front of the grill and can’t find it.My truck didn’t come with the cold weather group package and the engine block heater so I know that at least the heater is on there.The block heater itself is right by the oil filter, start looking there. If you don't have a cord, Geno's Garage sells them cheaper than the OEM and their probably made by the same manufacturer.
Found it! Man they hide those well! It was tucked up under the grill way down low. Thanks again.You have the cord, look around the passenger headlight, you might need to look under the plastic cover by the radiator
