What is this squeaky squeak??
gofishn
Iowa
hemi 5.7L, 345 cu in
Sounds like Exhaust, to me.
Grab heat shield and see if you can move it any.
Dodge 1500 4X4
Rochester, NY
Not exhaust, sounds like the roller on the lifter is gone, and the cam is about to get wiped out, pull the valve cover, and check rocker movement, do you have a misfire to tell you which cylinder, a mechanic stethoscope may help you.
AlbertaRam1500
AlbertaRam1500
Alberta Canada
Hemi 5.7 V8
Bingo. You got it. No misfire as of yet. Lifters/Camshaft in process of getting replaced. Also, adding new aftermarket manifolds while they’re in there.
