POINTMAN380
I have been using PUP 0w40 in my 6.4 and the K&N filter. No issues at all
BITOG = Burla is the oil guy.
Betcha don't want that title. LMAO
Burla, does the valvoline euro spec 0w-40 contain moly? I'll do a search myself, but likely won't find the info. Does redline make a 0w-40 for the 6.4?
Thanks.
Valvoline maxlife 5W-30, with a Napa gold filter( wix filter)
ha, BITOG has it's uses, getting accurate info for the hemi aint one of those uses.
Redline makes a 0w40 for the 6.4, but I don't recommend that. To get into it, 0w40 is super class oils, and redline runs a bit thick for my taste. Super class oils = best effort of many manu's, especially PUP 0w40 by far the best PUP oil. Manu's use 40 weight to skirt API rules on additives, and they make 0w40 right on the viscosity line. If I had a 6.4, I would use 5w40, 5w30, or even 0w30 in redline high performance before I'd use 0w40 redline. Post that question in syn thread as I know a few 6.4 owners that would probably back that up. I would only use 0w30 redline in a 6.4 if I had cold piston slap.
I'm not sure about the question you asked on Valvoline euro, I would say it is in the super class oils and has great base oils, viscosity index of 180 is very impressive and that oil has every desirable spec plus fca hemi spec. I would love to see a uoa/voa of this oil. It is "probably" low saps which means low additives, but with those great base oils I wouldn't worry about that. I might run this over redline 0w40 but dump in some biotech moly. It looks like a real contender for the 6.4.
Wix seems to Always be a popular oil filter.
Yeah my instructions state use of 5W-20.
However it doesn't say anything about full synthetic or blend but I'm going to go full synthetic for sure. now I did turn off MDS you think I could go with something little heavier, because I turned it off?
Sent from my Pixel 4 using Tapatalk
Amazing to watch another oil thread catch fire so quick...a never ending instigator for conversation fosho!
BigDaddy, glad to hear that motor is still singing for you brother.
I use Redline 5-30 officially as of last oil change. 4500k miles later and the motor continues to get smoother and quieter now pushing past 41,500 miles on the clock.
Have always used the RP filter. Seems to work well but I sure don't like how small the dang thing is!
