What Octane Is Everyone Running
Discussion in 'Engine & Performance' started by basegroup, Nov 18, 2018.
  1. Danielgetya
    Danielgetya Junior Member
    Sep 9, 2016
    Ram Year:
    Engine:
    Only use 93. Keep the engine at optimal performance and I actually get better gas mileage I did a little survey in for me that’s what works
  2. turkeybird56
    turkeybird56 Military Vet 1976-1996 Retired US Army Military
    3,412
    3,301
    Aug 2, 2018
    Central Texas
    Ram Year:
    2019 Bighorn, 4 X 4, 3.21 rear, Bright Red Crystal Pearl Coat, pending bed lining
    Engine:
    Run 89 octane, and try to stay with high usage stations, not Mom and Pop.....
    shmedley likes this.
  3. Fabian805
    Fabian805 Junior Member
    39
    Mar 5, 2019
    Ventura
    Ram Year:
    Engine:
    I used 91 Shell Nitro and for me its the Best compared to Chevron with Techron. Feel my truck more responsive and super smooth @ idle
  4. Elkman
    Elkman Senior Member
    59
    132
    39
    Aug 21, 2018
    Monterey
    Ram Year:
    Engine:
    V6
    Doesn't anyone know what the octane rating actually means? It is not a measure of the btu available from the fuel. It is only a measure of pre-ignition which results in engine knock which is damaging to the truck. The higher the compression ratio of an engine the more prone it is to pre-ignition of the gas when it first is injected into the hot cylinders of the engine. The higher the compression ratio the higher the recommended octane fuel that is recommended.
    If a lower than recommended octane gas is used the computer will retard the spark automatically to compensate and try to prevent pre-ignition and engine knock. The result will be less power and probably fewer miles per gallon.
    But if an engine is designed for 87 octane gasoline and one decides to put in a higher octane gas, then all they are doing is adding to the riches of the Koch brothers who already have billions of dollars and own our government so they do not need your charity. And with the money you save you can have the local tire shop put 100% nitrogen in the truck tires or invest in bitcoin.
    corneileous and SYKRAMMAN like this.
  5. UrWifesFavorite
    UrWifesFavorite Built to Grip & Ready to Rip Supporting Member
    46
    40
    Apr 8, 2019
    Washington for now but GUAM is Home
    Ram Year:
    Engine:
    6.4 SRT
    Sent from UrMoms House
  6. TerraNewf
    TerraNewf Senior Member Supporting Member
    62
    1,367
    456
    Mar 14, 2015
    Ontario, Canada
    Ram Year:
    Engine:
    89 octane here
  7. buddy guy
    buddy guy Senior Member
    57
    755
    549
    May 22, 2019
    alberta
    Ram Year:
    Engine:
    87, not a tow truck for me, Ram runs fine on it. 13 cents a litre more for 89 it's not going to happen.
    When I had my Victory Magnum bike, it was supposed to require 91 I think. Fk that noise unless it pinged on me.I ran 87 on it and unlike the Ram no built in timing retard to compensate. A proper tune for the engine did a better job than premium fuel ever would. I kept a bottle of Lucas octane booster with me on trips in case I ran into some questionable gas.
    But to each their own!
    tidefan1967 likes this.
  8. seabrook
    seabrook Member
    50
    77
    47
    Nov 14, 2018
    seabrook
    Ram Year:
    Engine:
    5.7 3.92
    Yea from ur list above ull b ok I have a few boosted items that need 93. My old truck had 3 different tunes on the fly and I could never tell the difference between the 87 and 93 tune- only the tow tune u could tell a difference because it still had the WOT restriction in place and the throttle sensitivity was dialed down
  9. Zachary Williams
    Zachary Williams Junior Member
    40
    11
    Sep 1, 2018
    Brenham Texas
    Ram Year:
    Engine:
    5.7 hemi 4wd
    89 at least and ill usually go to murphys but will not go anymore generic than that!!! decnt price, decent gas.
  10. Lucy Girl
    Lucy Girl Military, Army Veteran Supporting Member Military
    72
    303
    148
    Nov 27, 2018
    Mt. Vernon, Texas. 75457
    Ram Year:
    Engine:
    87 but no corn ethanol additives here. I also use Lucas in every tank.
Share This Page
