What offset do I need?
14SLT
I'm currently running 325/60/20 BFG Mud Terrain KM2s on my stock 20x8 chrome clads. I want to move to a 20x9 or 20x10 wheel. What offset would I need to keep my tires where they are now? I'm not running flares and don't want them out any further.
Thanks guys!
PassivAggressor
That will be pretty impossible I think. You are already close to rubbing or rubbing on your upper control arm now. If you want to keep your tires where they're at and go with a wider wheel then you'll need a good bit of positive offset, which will bring the tire even closer to your upper control arm guaranteeing it will rub. If you want a wider wheel then you'll have to have some negative offset.
14SLT
14SLT
I'm running .25" spacers and not rubbing my UCAs but do slightly rub the sway bar end links at full lock. I definitely can't afford to go any further in either. Maybe flares will be my only option.
temas87
New truck, help lol
What's the biggest size I can do on tires with stock suspension ? I'm also thinking about putting 3 inch wheel spacers cuz I like the wide look any thoughts
stevenmicheal
