what oil to use 3.6L (2016)
b3nny
Kingston
3.6 Pentastar
Says 5w-20 on oil cap, but everything online says 0w-20 synthetic? I bought the latter am i good to go?
Thanks
JB
HuskerRam
Tucson, AZ
3.0 Ecodiesel
Yeah, you’re good with 0w-20. It’ll work just fine for your engine.
b3nny
b3nny
Kingston
3.6 Pentastar
Beauty thanks very much!
Burla
2010 Hemi Reg Cab 4x4
You have to talk brands and specs they carry when you are trying to compare 5w20 versus 0w20, in many cases the 0w20 will out perform the 5w20 in cold and warm properties, or in cold and the same warm properties. if it were my 3.6 I'd be looking for the best 0w30 dexos oil was out there regardless where I lived. I wouldn't use a boutique as I see no need for it, no conditions facing that engine such as we see with the hemi, and no heavy rpm's either. If I had a costco near me I'd settle for 5w30 in kirkland.
The reason for 5w20 has to do with CAFE and not what is best for the engine longevity. There is an outside chance a 30 weight would throw a code, especially in the cold, but it would be a harmless code p0520 or p1521 if it even did.
danielmid
Southeast WI
2015 Sport 4x4
Not really - the OP just has to follow Ram’s recommendation for oil that is contained in his vehicle owner’s manual (including viscosity and specification).
Right, that's why there's 4000ish pages discussing oil choices, cause we all use what the manual says, it's a boring thread.
howie12
Iron RIver, Wi 54847
Pentastar V6 gas
I have a 2020 PEntastar and the cap says 0w-20. the 20 indicates the viscosity at high temps and the 0w or 5w at cold temps. I don't believe 0w-20 oils were readily available in 2016 and as oil technology got better they became more readily available. I would expect 0w20 to be an inprovement over 5w-20. It will provide easier starting and better lubrication when cold and be the same when it is hot. I have used 0w20 in my 2018 PAcifica Pentastar and my 2020 Ram 1500 Pentastar for a total of about 85,000 miles and done oil analysis on each change. Once I ran to 15,000 miles to test and see what it looked like and it was fine. Likewise all the nominal 10,000 test results were good with viscosity fine, wear particles fine , base number fine, fuel dilution minimal and residual additive markers fine. I am using AMsoil Signature in the Pacifica and Shell gas engine truck rotella and no significant variation in life or performance that I can see.
If I were you I'd use a high quality name brand 0w-20 full synthetic.
WI
3.6L
Why would you base your choice on what some guys on-line think? Who makes them experts? Do you own research, and make an informed decision ;)
danielmid
Southeast WI
2015 Sport 4x4
If you can find a better place to research oil than a forum filled with people with your exact same truck and engine, who regularly post test results, have at it.
Different Drummer
North East
Pentastar V6
Where are you finding the Rotella Gas Truck? Well, maybe I should ask, where are you finding the Rotella Gas truck at a reasonable price? I had settled on it s my oil of choice and suddenly I could not find it locally. My understanding was that Shell had stopped producing it.
06 Dodge
Forest Grove, Oregon
6.7L CTD
My understanding its now called Shell Rotella T6 Full Synthetic Multi-Vehicle 5W-30 diesel oil, its also API rated SN for gas engines and can be found on Amazon for $33 gallon, Napa for $36. or Walmart.com for $33
Different Drummer
North East
Pentastar V6
I think that Rotella T6 multi-vehicle vehicle was around long before Rotella Gas Truck. I have not researched any oils in quite some time and perhaps my memory deceives me on that.
I also recall ( perhaps mistakenly) that the Moly in RTG far exceeded the Moly in the Rotella T6. I think I posted a while ago somewhere on the forum that VOA of RTG and QSUD were very near to being identical. Both of course made by Shell. And, I believe both using GTL technology. Additionally both having been removed from production. Under those names at least. Who knows! The oil business seems to be in constant change.
I do see what is apparently NOS RTG on the usual internet venues. However, the prices are often comical.
