StNick
A couple of things to think about: One, as someone said, tongue weight (10-15%) is really, really, really important. The second is what will be your maximum total gross weight? A class 4 frame hitch (forget about a bumper hitch) is rated for maximum 10000. However, a class 5 frame hitch, like mine, is rated at around 16000 pounds and you normally don't need any special license. In Calif you're good to 26000 gross. Make sure any trailer you get has good brakes and get a brake controller for your truck that lets you activate the trailer brakes by themselves. This helps if the trailer tries to sway. Good dump trailers are heavy (mine, a 6x12 weight 3000 lbs empty). And make sure the trailer tires are capable of handling the weight you plan to put into it. I have done lots of towing so any questions go ahead and ask. Remember, take it slow until you get used to it and know how hard the trailer pushes you when trying to stop. Also, make sure you have good safety chains cause you're responsible for any damage if it comes loose.
