Whats the lowest offset I can go to run 35's
VasileRN
SW WA
Hello! I've spent a lot of time browsing for what the lowest offset I can run with a 20" wheel, preferably 20x10. I have a 2.75" level on my 2018 2500 and I'd like to not rub nor cut fenders.
I've also heard that the level isn't going to do anything for my clearance.
Thanks in advance!
Ohio5pt7
Ohio
-44 which is a 12 wide any 10 wide will work. And yes a level increases clearance.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
V
VasileRN
SW WA
I had 20x10 -25 with 35's and it would rub very bad when getting close to full lock unfortunately. Just trying to prevent another situation where I purchase wheels and tires that don't fit
Ohio5pt7
Ohio
Sorry thought it said 33s. Have you looked at customoffsets gallery
V
VasileRN
SW WA
Trying my best to search for it so I don't ask questions that have already been answered, but I haven't seen it. Could you send me a link for it?
Ohio5pt7
Ohio
Yep no problem
Ohio5pt7
Ohio
You'll have to copy and paste the whole link
olyelr
Kewadin MI
And you are correct, adding a leveling kit or small lift kit (that does not have bumpstop drops or extensions) with not truly gain anymore tire clearance than stock...the suspension still cycles pretty much in the same area as stock, just has a little higher at ride height.
