ashman155
- Sep 9, 2021
- 21
- 13
- Location
- Edmonton,Alberta
- 2018
- 5.7 hemi
Bought brand new tires for a 2018 crew cab at a tire shop Kal Tire. they told me they couldn't do a wheel alignment with the new tires. Asked why?? said that the adjuster sleeve was welded to two nuts on either side of the adjuster. I damn near fell out of my chair when told that. Soo I get ahold of the dealer make an appointment told yep this was a recall and the engineers idea was to weld the nuts to the adjuster sleeve so that they don't become loose and create an accident when driving. I said you got to be kidding me. Nope was the reply. when it was all done yep you guessed it they tack welded the nuts back into place on the adjuster i talked to the shop foreman about this and said would it not be sensible to use two more nuts to counter act against the nuts that hold the adjuster into place. Yep was the answer anyone with half a brain knows that, but our bright engineers thought this would be better. So now you got a front end mechanic to weld all this back into place after he is done. My question is are these guys qualified to be welders also to do this job? Scary thought. This has lead to big manufacturers to force you to take their vehicles back to the dealer to get this job done of a wheel alignment. What about other car manufacturers do they do the same thing for front end work. talk about a scam to get you in the door and hoping you buy a new vehicle from them while yours is getting fixed.
