Wheel Question
daveray9
probably a dumb question but has the wheel changed from 2012 and up?
Looking to snag a set of stock BLACK Sport rims off a 2016 for my 2012 just not 100% sure they fit. Should correct?
I have a sport with 20s so looking for the same, just black.
MADDOG
Living in a Firepit
6.4L HEMI
The two years have exactly the same wheel size, bolt circle, centerbore and offset.
quietpeen
2021 TRX
Hellcat
No the wheels have not changed. The thread pitch on the lugs did change though so if the black wheels come with his stock lugs do not use them
muddy12
Indiana
Still a good idea to check the fit before just running on the lug nuts with an impact, but everything I have found while looking for wheel spacers, states that 2012 and up use the same size lug nuts.
2011 and older had 9/16"studs, and 2012 and newer have M14x1.5 studs.
quietpeen
2021 TRX
Hellcat
Still a good idea to check the fit before just running on me lug nuts with an impact, but everything I have found while looking for wheel spacers, states that 2012 and up use the same size lug nuts.
yea, it might have been 2012 that they changed the thread pitch, i might have mixed that up with the uca's
stevenmicheal
