wheel spacers
beveballs127
I'm thinking of running wheel spacers on my 13 ram 1500 cc. I've ran them on my 95 camaro for years without any problems. I made sure I bought a quality hub centric set. I'd like to hear some input from people who have personally used them on there trucks. Either good or bad. Trying to make an Educated decison. I want to run either 2" or 1.75".
Reactions: HTX
Ixxblitzxx
Erie, PA
Magnum 3.7
When I had my 33s I ran 2" eBay hubcentric spacers for a couple thousand miles, no issues, made sure to properly torque and loctite them. They didn't wear out any parts either. Stepped up to 35s, went to 20x12 rim, took them off because it rubbed like crazy. Eventually got 4" more of lift, spindles pushed my front tire out about 1.5" more, so I added the 2" spacers in the back and got some .25" for the front, I did a front end rebuild with new tie rod ends, ball joints, and control arms because I couldn't pass up the deal I got on the kit. So far no issues, I've gone offroading, nothing too crazy, and I've towed about 1500 lbs with them, works fine for me.
B
beveballs127
Excellent. I was planning on buying some quality spacers and replacing the studs with some high strength arp studs for piece of mind. My truck is stock ride height so I figured it wouldn't be much added stress. Trucks are designed to be loaded up. So I figure this wouldn't make a much of a difference on durability
xrsman
Ontario
3.0 Ecodiesel
BORA makes a very high quality wheel adaptor. They're hub centric as well. I had their 1.5" adaptors on my last truck for 35,000 kms without a single issue. I towed a lot too. Great product!
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
I second Motorsport Tech's BORA spacers. I run their 2" spacers with my stock wheels and 37's during the winter (and for a year when I first lifted my truck) and haven't had any issues at all. They've stood up to offroading, towing 10,000 lbs, and 45,000km of daily driving. Great product and company to deal with.
BlownGP
Houston/Baton Rouge
Been running some adapters from MyWheelAdapters.com for about 2 years now.
No issues and only paid $140 for them!!
miguelherrera4
Agree. So far bora has been good. I run 1.75 upfront and 1.5 rear. I had to cut for the 1.5 tho. But went off-road the other day and no issues.
Sent from my Nexus 6 using Tapatalk
Ronan
Same here , 1 3/4" BORA's. Zero issues. I did t change my studs or have to cut, but I did use blue loctite. I also drive the **** out of my truck!!!! afc3061032f636e0c465cb40fb68e22e.jpg
madrock
Some tire shops won't touch vehicles with wheel adapters. That's one drawback.
As others have said, BORA is the way to go. Made in the USA too.
miguelherrera4
^^^^ this. Like three shops wouldn't touch my truck with the spacers on
B
beveballs127
This is exactly what I was hoping to hear. Does anybody have pics of their trucks with spacers? That white one looks killer. Can't tell but are those Stock sport wheels?
B
beveballs127
Just ordered a set of 2" spacers. Can't wait!
Ridgeline
Diamond Bar, CA
3.6L V6
Thanks for this thread, guys. I'll be receiving my 2" hubcentric ebay wheel adapters on Tuesday and I was worried everything would work out. Sounds like I'm over thinking the matter. The blue loctite is an excellent idea.
B
beveballs127
Got my 2" spacers on today. Forgot to take off the washers that hold the rotors on from the factory. Don't forget to take them off so the spacers sit flat!
Ronan
They are the stock 22" R/T wheels.... Thank you!!
H1Chester
To hijack this thread....
Is or has anyone used the Rough Country .25" spacer? When my Crapwrangler SRAs are done I want to put 305 wide tires and Bilstiens on with the tires sticking out just a little bit.
B
beveballs127
After a much needed bath
B
beveballs127
At first I thought 2" spacers were a lot. They are well worth it. Not only does it look way more aggressive but I can say that the corning has definitely improved. A lot less body roll.
B
beveballs127
Next I need to lower it.
stevenmicheal
