Right. The 19 speaker count thing is pretty much marketing hooey. A 3-way speaker (coaxial with tweeter, mid and sub) should never be counted as three separate speakers. But RAM did. As well, their claim of a 900 watt audio system is additional hooey. That is peak rating on all channels out of the amp on this system. Our ears hear RMS, not peak. (RMS is close to average although it's not exactly the same thing, but close enough for all but purists.) And the 900 watt claim by RAM is the sum of all amplifier outputs, not per channel as you will find on more detailed spec sheets. It can be important to spec peak power because if changing out a speaker, it is important to know the peak capability of that speaker and the peak capability of the amplifier output feeding it, so as not to blow out the speaker.
But if a company fails to specify the per channel ratings, their specs are pretty worthless in my opinion.
Now, that said, the RAM HK "19 speaker, 900 watt" system can sound pretty good to most people. If wanting still more performance, there are indeed aftermarket upgrades out there.
