Where can I find the orifice tube on my AC?
Jedi9
SC
2008 Ram Hemi, fixing to put in a seal kit and do a recharge on the AC system. Anyone know where to find the orifice tube location?
Curt Gobbell
Memphis TN Area
HEMI 5.7L
with the AC running, grab the AC lines and note where the temperature changes from hot to cold (normally sweating). The location of the temperature change is where the orifice tube is located as the freon transitions from a high-pressure gas (hot) to a low-pressure gas (cold)
J
Jedi9
SC
That is a good idea unfortunately my AC is not currently running because of loss of freon. Seems like on cooler days I can get it to come on sometimes. Dye was put in it and it is showing up at all connections
J
Jedi9
SC
Thanks, I assume the orifice tube is installed in the larger flared out end
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
just replaced one the other day they are in this line that runs from drier to evap core. the orifice is in the line behind air filter box and is several inch's inside it where it disonnects I have never been able to get one out on these trucks just replace the whole line the orifice is in the new line the line was like less than 30 bucks
Administrator
Close, the refrigerant transitions from a high pressure liquid before the metering device (in this case an orifice tube) to a low pressure.
