QuasarZ
If I want just the muffler which one should I go with? The center/center, center/offset, or offset/offset? I’m not sure what would line up better and need less piping welded. Thanks. I’m thinking of the 22” 5x11.
If you look at your OEM muffler the in and out are offset by about 5 inches so you will want a 5 inch offset in replacement muffler to stick to straight pipes.
I ordered the Flowmaster Super 40 with offset in and offset out for the 5 inch difference. I should need about a 7 1/2 inch of straight 3" pipe to make the connections to stock pipes.
Will see how it lines up, hooks up, and sounds in a couple of days.
2019 Limited Hemi
Moe's has what you need, go check 'em out. They carry direct fit.If I want just the muffler which one should I go with? The center/center, center/offset, or offset/offset? I’m not sure what would line up better and need less piping welded. Thanks. I’m thinking of the 22” 5x11.
