Which tires?
CanuckRam1313
Ontario Canada
2023 Warlock
I had LT285/65R20 BFG KO2's for my summer tires, and yes they look good and roll fairly well on the highway, but they are heavy tires, and they require a lot of weight to balance them out.
I kept them for two summers but as they aged they were more and more difficult to balance in terms of weight. They were checked for hop and belt shift and all was good. They were always road force balanced as well, and yes, they were stored properly and in a proper environment, too.
FFWD - I went to LT295/65R20 Michelin Defender LTX M/S tires this year for the summer rollers after taking off the BFG's. The Michelin's are a bigger tire, but they are about 5lb less per tire vs the 285-BFG's.
I gained almost a couple of MPG back now after switching to the Michelin's, and when they were road force balanced they were from 0.75oz to a max of 2.25oz per tire to balance them out. The BFG's were around 7oz up to 10+oz per tire when they were road force balanced.
I run 40psi cold in them front and rear and do mostly highway. They are smooth and quiet tires, and are appreciably more stable with better road feeling and control in the rain than the BFG's ever were, even when new.
Not knocking the BFG's or other AT tires as they look great and serve a purpose (I personally miss the look of them on my truck). But if you're only going off road once in a while and doing mostly on road and/or towing/hauling, the Michelin's are the tire to look at.
thkbaron
Minnesota
I have heard of people having balancing issues with the BFG's.
Tinman454
Saskatchewan
I have 40,000 km on a set of 35’’ k02’s very happy with them but I do rotate every 5km
Minotaur 013
Law Enforcement
Oregon
Kenda Klever R/T’s are the best tire for doing it all and for the price (which is cheaper than BFG, Cooper, Falken, Nitto, etc. ) IMG_2487.jpeg
HaydenHunter
Idaho
2017 Laramie Crew Cab
HEMI
I went from Michelin defenders to the BFG K02 because I drive a lot in winter and as a waterfowl Hunter, I am on a lot of snowy and icy boat ramps and roads pulling my boat. I love the KO twos for traction but I am thinking they cost me 1.5 to 2 mpg. Still, I would buy them again. Price of doing business in my situation.
Connie Mack
LA MARQUE,TEXAS 77568
5.9 Diesel
here is what I did. I found out the there are only 3 tire manufactures in the world. most reside in china. OK, ya say I ain't buying anything fromn china, well lets see. discount tires, tire & battery, and the big ones all get there tires from china. So here is what I did, went on market place on fb and found these "Red Dirt MT tires. they are raterd 8th in the world for quality. I have a 03 dodge 2500 4x4. hardley any wear so far. Oh, BTW, $604 for 4 tires, balanced the works. tire & battery, dfiscount tires, will never see me again
Snowchief
Milwaukee, Wisconsin
Ok, so I have 2016 Power Wagon that has 285/75/17 Geolander M/T G003 tires and the spare, from when I bought it a year ago. I live in Bellevue, NE so I get every driving condition there is. I honestly do no off-roading, sadly, so I definitely don't need a dedicated mud/off-road tire. She's my daily driver/pavement princess, but I would like to start venturing off the beaten path and use it for what it's capable of. I also don't tow anything. I think the size I have now is suitable for my needs. I'm just torn on which tire to get. I've done lots of homework and I've narrowed it down to either the Falken Wild Peak A/T 3W or the BF Goodrich T/A K02. So, my question to everyone is, if money wasn't an issue, and it's not, which of those two would you pick? I appreciate and welcome any and all input from the Power Wagon community. Have a good day all.
Neither I would run Made & Owned in the USA MasterCraft CXT all terrains
Robeffy
Northern Ontario
Cummins 6.7 TD
I just put a set of Geolander's 275/75/18 on my 2500 CTD, I ran these tires on my 95 1500 Ram. I really like the Geolander's, replaced the Michelin Defenders. Virtually the same ride quality, noise.
DwainGriffis
Tennessee
6.7L
I'm on my 2nd set of Firestone Destination X/T's (E- rated) on my DRW and got 55k miles out of the 1st set
Ram Vendetta
Lindenhurst, NY
Here's my .2 cents. BFG K02 are absolute TRASH now.
I was a loyal BFG guy since the 80's but in about 2015. -2018 their quality went downhill FAST!
With reg rotations, alignments & balances I was getting 20k miles out of their PATHETIC tires before balding. 2 sets and NEVER will purchase again.
Tominator223
We always just called tires 6ply or 10ply. And we always used 10 ply on 2500’s. # Referring to side wall construction . For pavement I always use Michelin . I would almost always get 5k more miles than they where rated for. So that why I kept using 10 ply . On a 2500 & 1500. I did have some off road BFG’s . They were good , but it’s was a lil luv truck that never saw pavement . So I have no idea on road noise from the BFG’s. I believe 10 ply is standard on almost all 2500’s. Have you look at Hercules tires? I’ve head some good things about em. But have no experience with em. Might be an option. Good luck
olyelr
Kewadin MI
Totally agree. BFG are trash tire that wear unbelievably quickly now.
I put the stock size ko2’s on my half ton work truck. No complaints from me yet. I have 13,270 miles on them now and they still look new. I will have to keep an eye on them to see if they disintegrate in the next 6k miles.
akguy09
Ellicott, Colorado
They are probably fine for a 1/2 ton, they are garbage on anything else....overpriced crap...but the fanboys love them
ppine
Forester
Nevada
6.7 liter diesel
Tires have improved so much, and younger people seem to not understand this. It is hard to comment on tires when so many seem interested what looks badass instead of function. By all means go with load range E tires. Don't go too big because you just lose power. For snow,tall narrow tires are best. Wide tires in snow are a disaster.
Plenty of good brands like Cooper, Toyo, Nitto, Falken, Michelin, etc. I run stock sized tires, because that is what the truck is designed to run on.
