Sending PM
Even the HP tuner sometimes doesn’t clear everything.
I would check the oil level, disconnect battery, do a capacitive discharge. Disconnect and reconnect the PCM connectors making sure they are seated all the way, and none of the tabs have popped out. They’re really bad for coming apart.
If you still have issues, maybe try reflashing with HP tuners, and clear adaptive memory with HP tuners.
After that you might have to check that wiring. I would maybe contact whipple before doing that.
Also if you want, you could send me your tune and I’ll compare it to the one whipple sent me and see if I can see anything that may be causing it.
It’s entirely possible the PCM has an internal issue, especially with those dtcs and the fact that it drives fine with no issues.
I'll call HP tomorrow again. I still have my original PCM I could send to have unlocked. Are there better places to send for unlock?
I don’t know if someone else can unlock it and still have it work with hp tuners.
You could try getting the original PCM unlocked and see if that helps.
When you had everything off did you take a good look at the harness that goes to the oil control valve? As well as the connector that’s on the driver side at the back of the head.
You mean the crankshaft bolt, not the camshaft bolt right? From when you drilled it for the pins? It won’t matter if the crank pulley moved slightly when tightening the bolt.
Only reason I was curious...instructions say "**DO NOT LET BALANCER ROTATE WHILE TORQUING."
Ya, they have that warning in the instructions, but it’s not going to mess with the timing if it moved a little. It’s more for getting the proper torque on the bolt.
I would be leaning towards the PCM as well.
That’s cool I’m glad you finally got that all worked out. Now you can focus on other things like painting. LolDrove it...no lights. Damn PCM...now to try to get my money back for the first one.
