Wife jumped her car, no power steering
EvoNiner1986
So today my wife decided to jump her car by connecting to what I believe to be two fuses on the battery of my '16 ED. I now have no power steering. Looks like there's a 125a and 250a fuse that she probably blew. I ordered replacements from the dealer but wanted to see if anyone else has done this before? When the new fuses arrive is it as simple as putting the new ones on and all will be well again, or am I missing something? Thanks in advance!
clh1220
st Louis
That's one thing I don't have to worry about . My wife won't open a hood. Hopefully it's just a fuse.
U&A
2016 3500 SRW
6.4 HEMI
It should work fine after you replace the fuses. I would disconnect the negative terminal for a few minuts while replacing the fuse to help reset things.
Cant hurt
MADDOG
Out Exploring Arizona
Disconnect the battery before you pull and replace the fuses.
E
EvoNiner1986
Haven't thoroughly looked at it but I caught a glimpse of the positive, didn't see the negative as most the battery was covered with the insulator
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Did you actually check the fuses or you shotgunning parts at it?
E
EvoNiner1986
Didn't check the fuses but knew it HAD to be the cause as the jumper cables were attached to them, and my suspicion was confirmed tonight when I replaced them and got my power steering back! In case anyone else ever makes this mistake, here's the part numbers for the fuses. There's a 125amp and a 250amp fuse.
125a-68250096aa
250a-68241002aa
Administrator
Is there two or three fuses? On my '15 EcoD there is three.
Battery mounted fuses, the terminals with the black caps can not be used to jump start or charge with:
E
EvoNiner1986
You're correct, there are in fact 3. Nothing was hooked up to the 3rd fuse (the one between the 125 and 250a) so I didn't bother with it. Didn't even look to see what amp that one was. Funny thing in the manual it only shows the 2 I had originally mentioned, didn't say squat about the other one LOL
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
125a-68250096aa
250a-68241002aa
For those fuses to have blown, she got the polarity of the jumper leads crossed when she did the jump.
huntergreen
125a-68250096aa
250a-68241002aa
good info to have, tks.
