Will a 8.4 touchscreen from charger fit in 2017 ram 1500
Mark2003
North Carolina
Looking at infotainment unit from a charger 2016 but not sure if it will fit in a 2017 ram 1500
18harvest
huntsville
mount is differant.jeep cherokee and ram are the same.a durango mount can be made work.
Wilmer
My assumption(s) would be:
If Infotainment is a reputable vendor, then they should be able to provide a unit that will fit/work. If it does not fit, there should be no cost to customer.
18harvest
huntsville
Wilmer he means infotainment unit /radio not infotainment the vender.
18harvest
huntsville
Compass,ram,both cherokees the same mount.keep in mind it has to be a uaq or uas within a certain time frame year wise to work.ram 18 and ram classic thru 2021.not sure on the other models.i have had good luck with 18 thru 20 la car radios.i would recommend trying to find a ram part number though
