geekything
- Sep 10, 2017
- 135
- 36
- 2018
- ecoDiesel 3.0L V6
Pulling an ultralight (3000lb FULLY LOADED) travel trailer. 380lbs tongue weight. Connected to my factory class IV hitch.
RAM recommend a WDH at over 5000lbs, so I'm guessing they mean 500lbs or more of tongue given they like to exaggerate and always use 10% tongue ratio.
My current, as weighed on a CAT scale, axle weights are 3500lb front (diesel!) and 2600lb for the rear. The rear wheel arches are about 2.5" higher than the front right now.
I desperately want to avoid a WDH because I'm very tight on payload with an ecoDiesl Laramie 4x4. Can I do it?
I'm quite prepared to add a set of the low-end Air Lift bags to the back shocks if it will make a difference.
