Will Ram use the Titan v8?
nlambert182
Huntsville, AL
It's strange that you've had so much trouble with 87. I think I've ran one tank of 91, with no discernable difference. I've run 87, 88, 89, and on several occasions E30 (94) and I've never had any knock or noticeable difference in power. I don't tow super often but when I do it's usually kind of heavy, as I've been in the 20k pound neighborhood a number of times and even then, never an issue with 87. My brother's ram has the 6.4, tows all the time, and I know for a fact he only runs 87.
To be clear on my earlier statement with running 87.... that was not with my Hemis. That is in the Nissan. My 5.7 Hemi ran 87 just fine. The tune on the Armada Platinum prevents cleanly running 87. You can run it in the Titan just fine.
ramffml
ramffml
ramforum
There is no world where integrating an engine completely foreign to all other aspects of the vehicle is more cost effective than keeping what they have. Just integrating parts alone into the system would be monumentally expensive.
You're not reading the article and comments. There is no chance of getting the 5.7 back because the tooling has been converted for the hurricane. They're not going to open a new factory for this when it can get shutdown in 4 years again.
The fact that cummins, pentastar, 3 different hemis (5.7, 6.4, 6.2 supercharged), 2 different hurricanes (SO, HO), ecodiesel etc all get dropped in these rams shows that integrating another v8 is not "monumentally expensive". I have no idea where you got that idea, it's not true in the slightest.
It's not just me. Others have complained about it on this forum, or logged it directly from their ECU. In fact, the Ram manual at one point even said something along the lines "a small amount of ping is normal". You don't put that in the manual if guys aren't hearing it.
The uncomfortable truth is that many guys:
A) can't hear it (ears aren't good enough anymore)
B) won't hear it (radio on, talking etc)
C) don't know what to listen for or what it sounds like
D) aren't in the same conditions (humidity, heat, load on the engine, gas quality etc)
I've had one of my brothers not hear a thing in my truck when I clearly did, and neither did my mechanic. It's not a terribly loud sound, it can easily get lost in the noise of the truck or your conversations. You have to know what it sounds like, and listen for it. I've put a video here on the forum from another truck on a dyno, demonstrating the ping, even trying to isolate the sound as much as possible and many guys didn't hear it either.
The 6.4 in the 2500 has a very conservative tune. It would not surprise me in the slightest if there is no pinging under load in that truck.
Burla
2010 Hemi Reg Cab 4x4
Not sure what you mean by "simple V8". Given current emissions and fuel economy standards I don't think there is anything simple about any modern engine compared with engines from even 20 years ago. If you're talking about a V8 without cylinder deactivation or any kind of mild hybrid system then I agree completely. I don't see it happening, but I'd buy one as well.
The results of the last election will likely only delay the march to ZEV's. Auto companies are somewhat used to responding to the political changes that can happen every four years, and are forced to make decisions based on long term trends. In the end there is a very real chance than anything that happens in the next four years will be reversed anyway. So I don't see them investing a lot into bringing back a V8 option. I really hope I'm wrong about that.
just efi, low rpm tune, low HP = last forever and a day, no synthetic oil needed, lol. Simple CPU, no nothing no tire sensors no evic no nothing that can break. I think you could run codes with a paper clip all the way though 96, maybe longer. Started in late 60's fords and the reiteration of the 351 lasted through the nineties. I owned several of them, to me same ilk as Chevy 350's in those years. The engines we left behind for this MDS isht and now di turbo's. At some point before I'm dirt I'm gonna find a 90's Ford with a 351w and call it a day with a smile on my face.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
If you do find one of those, find out if she has a sister :D
Burla
that's what I told one of my best friends, he just found a 12 valve Cummins for 10k. It's now his daily driver, lucky bastage! I kid you not, he found it in a barn, and I have the pic to prove it... The next 12 valve barn find he said is all mine, he finds these things he is in the "know".
tjfdesmo
AZ
I towed a 41' toy hauler with a 6.4/66RFE combo that went across the scales at 23,160 lbs, and even on long hard grades, at pretty good elevations, winding to the moon, it never pinged on 87 octane, which was its steady diet. The couple times I experimented with 89, the only difference I saw was a lighter wallet.
DanAR
Arkansas
My 23 1500 seems to run just fine on 87 although I haven’t towed anything more than a small trailer for dirt and gravel. I’m not sure what the prices are like elsewhere but I went down to the Mobile pumps yesterday for some 87 lawnmower gas and noted that 89 octane was $.80 more a gallon and 93 octane was merely $.10 more than 89. If that is typical and I didn’t believe 87 was good enough, I don’t think I would mess with 89 octane. Might as well just get 93 for .10 cents more.
Kickboxer
ND
5.7 Hemi-non-Etorque
Ramful, I think you are just full of yourself. Stop it right now.
I suppose 90% of the miles on most Rams are driven on 87 octane.
Your drama is interesting
ramffml
ramffml
ramforum
jws123
nj
I found this article worth a read and found a new take on this: could Ram use Nissan's v8 from the Titan even if just limited numbers? IMHO this would be a very smart move depending on the effort it takes to integrate the ECU etc, but it could help both companies as Nissan is down right now as well. And that v8 has a good reputation (other than manifolds, lol)
I dont feel like reading all the comments . However The titan engines SUCK! have rebuilt some at work they are crap.
ramffml
ramffml
ramforum
Well good news, it seems that Ram is working on a new v8.
nlambert182
Huntsville, AL
What specifically makes them crap?
I would wholeheartedly disagree. Whether they stick them in a Ram or not... they're good engines and have been around a long time. I sold my 05 Titan with almost 200k on the ticker. Engine and trans functioned like new. Our current 2021 Armada has the same 5.6 that was in the 05. We're at 65k on it and it performs flawlessly.
I'm a Ram fan, but I can't speak down on the Nissan drivetrain. Frankly there have been less engine failures with the 5.6 than the Hemi with the cam/lifter issues.
runamuck
dfw
6.7 dsl
looks like they are going to have the 6.4 around for a while. could just offer a version of it in the 1500's for little new investment. GM still using their 6.2 I think. might be good for fleets and old guys like me that like less tech than the straight 6 to maintain.
jws123
nj
May just be a few of the newer ones but they have piston slap we replaced the short block on a few already.
