marquette1080
Wind noise in cab (usually from passenger side). You can hear while driving. Not sure if it occurs on every truck and most people just don’t notice it, or if only happens on specific vehicles. The noise is better or worse depending on which way the wind is blowing, but even when it is not windy out, you can hear the change immediately if you follow the below process:
If you have the heat or A/C on (keep it low so you’re not hearing the fan) you hear the wind noise. As soon as you turn the system off, or turn it to recirculate, it goes away. It’s like you can hear when the outside air is being pulled into the system.
Has anyone else noticed this?
Is there a fix for this?
Where is the vent that the air is pulled in from (would like to cover it to see if it makes a difference)?
