Window auto up wont work
Itsme71190
Las Vegas
2015 laramie. Auto down works fine, but driverside auto up doesnt work. Bad switch?
The kracken
Mississippi
Ive had this happen multiple times and sometimes it just starts working. Take the hot side of the battery cable off .its worked for me
Sent from a device thats sends stuff
Itsme71190
Itsme71190
Las Vegas
Word. Ill reset it
MADDOG
Living in a Firepit
6.4L HEMI
To recalibrate:
1. Open the window holding the switch down. Hold the switch down for a count of three after it bottoms out.
2. Raise the window holding the switch up. Hold the switch up for a count of 3 after it totally closes.
Repeat steps 1 & 2 at least 3 times in quick succession.
meedom
Maddog's instructions worked for my 2016 Big Horn too, although I think I only had to do it twice and it's happened once again since the first time...
TomA.
I have a 2015 Ram Lone Star Crew cab and have similar problems. I have auto button for both front doors but neither work. The passenger side goes up using auto button on the passenger side. I have tried the 3 seconds, the 10 seconds etc and nothing seems to be effective. Guess I can try disconnecting battery. Tom
grizzstang
Calgary, Alberta Canada
Too bad there isn't a way to turn off the auto up/down feature. My ham hands can't seem to find the split hair of separation between the two and every time I want to crack the window a little it engages and starts rolling all the way down.
Kenai Ram
Kenai Peninsula, Alaska
If you tap the button a second time in whichever direction you are moving the window it will stop at the position it is in.
kad
Hudson Valley, NY
5.7L HEMI
To recalibrate:
This just worked on my 2014 CC Express as well. I changed my door modules and mirrors for power folding mirrors this past weekend and despite making sure I had the proper switch, the auto-up function was not working.
-K
Bzubke1
To recalibrate:
I used this method on my 2016 big horn and it worked for me. My passenger front door auto down worked but not auto up. All good now.
stevenmicheal
