Window deflectors
SouthernBornRebel
Marine Corps Law Enforcement
Tulsa, Oklahoma
WeatherTech..... IN channel.... smoked......... can't go wrong...... don't get the stick on ones for the exterior of door.
SouthernBornRebel
Tulsa, Oklahoma
Hello all,
I installed the AVS in channel and the rears are bowed inward.
Not happy but I haven't been able to adjust the bow out, literally.
My next step is to remove the rears, heat them to remove the bow, maybe permanent, and try a reinstall.
Anybody have any ideas ?
Thanks
p.s. I have had no problems with the windows opening or closing, just the bowing.
WeatherTech is the way to go.... however, for your issue, put a piece of wood behind it, and use heat gun.... low temp, and NOT right on it.... experiment getting a little closer while waving it full length of the AVS... it'll reform as you apply small amount of heat and pressure...... Good luck.
Cyborg
Boulder Colorado
I put on AVS Charcoal or Smoke on my 2005. I prefer the out of channel type because sometimes the in channel can mess with window movement, and lead to window regulator failure. I love these and have had no problems at all.
Rebel4Mo
Billings,Mt.
I just installed the tape on AVS shades on our 2019 Rebel.
Easy to install and look good.
SixAddict
Phoenix, AZ.
2019 Ram 1500 Laramie
I went with the OEM ones from Mopar. Snap in fronts and rears are kinda tricky, they have small clips to go behind weather strip that attach to rear ones. They have been installed for a couple years, the only issue is going thru car wash soap doesn’t get completely rinsed from under them.:(
mark dog 007
TN
Stick on, 2 years, no issues, look great!
Raife
6.7 I6 Cummins HO Turbo Diesel
I just installed the weathertech one and seem to be doing just fine...but they have only been on a week...
Immerge
