Window switch doubt!
Claudio
New on Ram Truck and on this board: I have a 2011 ST Quad Cab 1500 4x4 w/ a Hemi 5.7, I changed the TIPM and now the lights on the dash for the seatbelt and for the airbag stay lit all the time, my question is : What should I do?, also, When trying to buy a passenger door window switch there are 2 options ( and they look alike on the photos ) that I do not understand why: One is for Quad/crew cab and the other is for standard cab; Question: Since they both do the same, what is the difference?
Thanks for any answers.
Tach_tech
5.7L HEMI
Did you push down the fuses for the ORC module? New TIPMs have those fuses only partially installed, to avoid any accidental deployment.
C
Claudio
Definitely I did not. in fact I do not even know what are they/how they look like/ where they are ! Can you help a little bit more?
Thanks
mowin
upstate ny
2017 3500 SRW
6.4 hemi
I could be wrong. It's happened once before, but isn't standard cab the same as regular cab? So only two windows vs four windows on crew/quad cab. Could be they just uses the same pic in there description.
Tach_tech
5.7L HEMI
Thanks
Open the cover to the TIPM, there will be two fuses together in a yellow holder, push them down.
C
Claudio
Tach_Tech. You are the guy !!!!!!! just checked the TIPM and pushed down the yellow stuff as you told me to do and : Voila! No more lights on the dashboard. Thank you very much
