Windows Up/Down on Entry/Exit
GordDavey
Toronto, Ontario
I'm hoping someone can clarify what I'm being told...
I'm told the driver and passenger windows go down 1" when opened and back up to closed, when the door is closed. This sounds odd to me. Is it true ?
BOWERSFJ
Uniontown OH
Not the 2012 Sport ...
BWL
Embrace the skeptisism
BC Canada
On my older ram you can press and hold the unlock button and roll the windows down, but I don't think they went back up. On the newer ones that feature has been removed.
GordDavey
GordDavey
Toronto, Ontario
No, this is not about the windows going all the way down. Just 1 inch drop when the door is opened, and then they automatically go back up when the door is closed. I'm being told this is normal behavior... to do with the amount of air pressure when closing the door, which sounds like bunk to me as that's what the baffles on the back wall are supposed to be for... but this is my first RAM so I don't know what is normal or not yet.
BOWERSFJ
Uniontown OH
What did the dealer say ?
GordDavey
GordDavey
Toronto, Ontario
I didn't get it from a dealer. We are rebuilding a wreck, which is currently already better than when it was new.
BWL
BC Canada
There's vents on the back of the cab for air pressure when closing the doors so that's not it.
GordDavey
GordDavey
Toronto, Ontario
That's what I said. Perhaps a "window reset" procedure will correct it. But apparently, right now when you open the doors the windows drop 1" and then automatically close themselves once the door has been closed. Weird to me.
BWL
BC Canada
I know when I replaced my power window cluster in the drivers door it didn't work properly until I disconnected the battery to reset so worth a shot. Any chance there's an aftermarket alarm system in there with some weird option settings?
BWL
BC Canada
With it being a wreck rebuild perhaps the previous owner programmed that feature in somehow. It seems too specific to be a fluke problem. Maybe somebody on the OBD2 thread could tell you if there's a settings option somewhere in the ecu.
GordDavey
GordDavey
Toronto, Ontario
Well, thanks everyone. I didn't think it was normal behavior, it would be crazy in my climate were windows get iced up all the time. I've got the Alfa app, and will look thru the settings to see if I can find anything. Hopefully the window reset procedure will correct it. Thanks all for confirming it for me!
oe542bob
Hemi eTorque 5.7
It is not normal. It is common on cars without a door frame at the rear and top of the window. My Chevy 2005 SSR and my 2009 Mustang GT 500 would drop the window about 25mm (1") as soon as you would move the door handle.
Have you tried cycling the windows up and down a few times? Sometimes they need to "learn" how far to go. But honestly, I don't know why this would even occur at all.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
We need pictures of the truck or you really do not have that RAM :) Would really like to see before and after pictures Thanks
BOWERSFJ
Uniontown OH
You want to see pictures of his window up, and an inch down ? ... Really ?
