Wipers running when in off position?
BleuCheese
Ringoes, NJ
I just picked up a new Ram 1500 and was looking it over. The only thing I did to it was add a Billet catch can ..fairly simple.
Afterwards, I don't know it this is related or not since I have only had the vehicle a few hours, but I was sitting inside the vehicle going through the radio settings and put the vehicle in the on position but not running.. This is when the wipers started to run and I checked the settings on the wiper control selector and it is in the off position. I couldn't get it to stop until I started the vehicle and then it continued to run for a couple of cycles and then stop.
This doesn't seem normal...any suggestions or have you seen this problem before.
Thanks in advance.
BleuCheese
BleuCheese
Ringoes, NJ
I think it does but it wasn't raining and the windshield was dry. I even turned the wipers to the off position. The only other thing I had done was try the remote start with the hood up which apparently doesn't work that way. One I shut the hood and hit the report start it fired right up. I haven't seen and other error messages.
txcobowhunter
Cabool, MO.
2016 SSV
My guess would be a problem with the sensor. I don't have the rain sense wipers so I'm not real sure how they work. I would at least contact your dealer and let them know about it.
BleuCheese
BleuCheese
Ringoes, NJ
Ok I'm going to let it sit overnight and see how it is in the morning. Thanks
baum
savage, mn
2015 Laramie
in order for the rain sensitive to work you need to have it on to at least the slowest speed on intermediate
BleuCheese
BleuCheese
Ringoes, NJ
Update: as of this morning they seem to be working fine. Maybe sitting overnight reset the computer somehow, but I'll keep an eye out to see if I have the problem again. Only had happened when truck was not running but the push button start was in the "Run" position.
butterscotch71
Central Ohio
2023 Limited Longhorn
Sounds like the rain sensing wipers to me too. I had mine go crazy (high speed) when I had a little ice on the windshield. Couldn't get them to stop. Finally had to disable them in the settings.
Hemi395
Cape Cod MA
The rain sensing wipers will activate when there is any moisture on the windshield. Could even be bird ****. My buddy has a 16 Laramie and his came on one day as a bird **** on the windshield. They're crazy sensitive...
BleuCheese
BleuCheese
Ringoes, NJ
Update: Dropped it off at dealer this morning and they said it was a malfunctioning switch. Ordering a replacement that will be in tomorrow.
RamCares
n/a
n/a
Thanks for the follow up. Please keep us posted on the outcome of the repair! Let me know if there's anything I can do to be of assistance to you in the meantime.
Erica
FCA Social Care Specialist
