First green circle - A904 is the circuit and circuit level (Im not sure what they mean by level). 10 is the gauge of wire. RD = red (color of wire)
Second green circle - 3 in the square means pin 3 of the connector. C2/B is the connector in the module itself (so BCM connector C2/B..pic attached so you can put it all together)
Third green circle - P235 is the circuit and circuit level again, 0.75 represents the wire gauge (NOTE: Im not sure what the decimal gauges mean, anyone that can answer I would appreciate it as well!), GN/BG = Green / Beige = wire color
You are correct about the line....there is an "inline connector" named Body/Chassis, the lock and unlock drivers from the BCM connect to pins 21 and 20 on the inline connector.
I can answer the wire gauge question. They are all metric cross section measurements in mm2. So, 10 in the first green circle would convert to 8awg, .75 is 18awg, etc.First green circle - A904 is the circuit and circuit level (Im not sure what they mean by level). 10 is the gauge of wire. RD = red (color of wire)
Thanks, starting to become more clear.... where can the actual line drawings of the circuits be found? Thanks
Try here: http://www.bbbind.com/tsb-wiring-diagrams-database/
I dont think Ive seen one big diagram for the whole truck, but each circuit has diagrams like the one you posted in your original post.
SpliceWhat is sp2338 mean
