Wobble when turning
GunnerJ
US
So I just replace the passenger side axle U joint, as it was totally bad, one of the Caps was even cracked and had no needle bearings. Since it has been replaced when I am turning to the left and sometimes to the right at moderate speeds and has a front-end wobble like it's in 4-wheel drive. It does not happen all the time, but when it does it is terrible. It won't do it at slow speeds like in a parking lot, and it only happens when I'm about halfway to lock when turning. Would that U-joint be the issue or should I be looking at something else, because it never happened before I replace the U joint. Any help is appreciated
Sent from my SM-N910V using Tapatalk
stevenmicheal
