WTB: 1500 rear axle w/3.92 gears
Status
Not open for further replies.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
My buddy has a 2011 1500 with 3.92 gears. His pinion nut is loose and apparently has been for a while. Dealer suggested he rebuild the diff or replace the axle. I think it might just need a tightening but I have not seen it in person. He's going out of town for a couple of weeks and when he gets back, we're going to unbolt the flange at the rear diff/driveshaft and inspect. If the pinion nut just needs a little tweaking, he should be ok, but if its backed out a lot, I'm going to suggest he find a replacement axle. So I'm looking here to see if anyone has one so we could line that up.
Karlsweg
SW Florida
Chances are pinion bearings are toast and gear oil will be full of metal!
Administrator
scott lass 18
rocklin ca
2010 ram 1500
mine cuz I change gearing games going on it was a new dodge ring and pinon too ! soooo sucks dodge so can anyone tell could they have turn and striped it dealler ! 45,000 on new one I had done hope didn't wreck my truetrack in it ! why they didn't fix my problem first the do dang recall !
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
I know where there is a 2017 Ram Sport rear axle with 3.92 limited slip. Truck has under 10k miles on it. There asking $800 for it.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
You can buy a ring and pinion and an install kit from Moe's Performance, a preferred vendor on this forum.
Jay
Eddie S
Banned
v6
I'm sorry but.......WHAAAAAAAAAT??????????
scott lass 18
rocklin ca
2010 ram 1500
was so luck and no gear were fine dodge the nut was strip when testing change fluid and a deron nut sooo better all set now was a 200.00 cost oh well they did a lot of engine work fuel injector exhaust manifold trains relay ? think other exhausted now ticking oh well ! sure hope in a few months can drive to the red wood sucks dec to know 500 miles !
Status
