WTB rear no cut brackets
Status
Not open for further replies.
xtremeroller
Holt FL.
2017 & 2008
5.7L HEMI
Looking for a set of rear no cut control arm relocation brackets to use on my 2017 Ram when I lower it.
Sent from my SAMSUNG-SM-G890A using Tapatalk
xtremeroller
xtremeroller
Holt FL.
2017 & 2008
5.7L HEMI
Still looking for a set but damn there are a lot of scammers that contact you through your wanted post.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I have a set, I ran on my truck for 6 weeks. I took them off, they are used. You will need to purchase the two bolts that go into the drilled holes in the upper control brackets as I put the bolts back into the holes I drilled to hopefully not weaken the upper brackets until I can buy the cut brackets.
Nothing wrong with them, other than the above. I decided to go cut as I going from a 4 to a 6 in the back and from a 2 to a 4 in the front.
Can't really do a 6 with the no cuts.
Pm me if interested.
xtremeroller
xtremeroller
Holt FL.
2017 & 2008
5.7L HEMI
Sent you a PM. Do you know what size the bolts are that need to be replaced?
xtremeroller
xtremeroller
Holt FL.
2017 & 2008
5.7L HEMI
I got a set from Bigskyroadglide. Mods will you delete this listing please.
Status
