Wtf
ercmesser
Tampa, Fl
I miss driving my baby. In August I ran thru a puddle, sucking a ton water in to the intake braking two rods. Rebuilt the motor go to start it and it starts and stalls with in a few moments check the oil and fuel is in it. What could it be I think Injectors are leaking. so weigh in and help me get back behind the wheel of my baby.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Fuel in the oil means that one or more f the pistons rings are bad. What most likely happened when you sucked the water in was some got into al the cylinders and messed up the rings on more than just those that broke the rods. If you can you need to do or have a compression test done on your engine, the cylinders that fail are the ones with the bad rings. Now seeing as you may have to do that I would put some much better pistons in your motor to make it a bit better. AirRam has these for the 4.7:
AirRam - Cold Air Induction System
and these:
Either set will work and which ones you get is totally up too you.
