xentec hids once again
hemi_hawk
still having all kinds of problems, here is my wiring harness set up
I am having all sorts of problems from my ballasts shorting due to water... all the way up to bulbs blowing and every thing in between.
any one use a kit such as xentec ? if so any problems and if so are you running it on auto or are you manually turning your lights off and on ?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
what the @#%_@#+ type of wiring is that ****?
DUDE.....
Is this a quad setup? If so, I can get you a WORKING harness for this thing for under $30 shipped.
H
hemi_hawk
ok well hook me up... thats the harness i got off ebay
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
you have the quad headlights right? (harness is different than the duals!)
quietpeen
2021 TRX
Hellcat
Wow that just looks like a electrical nightmare. What jj can get you will be 10 times better
H
hemi_hawk
oh sorry ya its a quad bucket.... it all was working for a while then some water got in the ballast connectors and blew the ballasts then one after another i would fix this light and that light or ballast would blow so id replace that and then this would **** up... so
blackout11
alpharetts GA
2011 R/T
DUDE.....
LOL was going to ask the same thing thats right there is why your having problems
H
hemi_hawk
well tell me what the heck i need so i can fix this once and for all... i want to just plug play and forget about it
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Here's what you need!
Posting this up - as all can use this knowledge. :D:D
Harness link - HID relay wiring harness - Retro-Solutions Store
For for your quads, select the "09+ Dodge Ram H11 Quad Lamp"
Also, 10% off if you use the coupon code "JJ".
When the harness comes in, you will want to use dielectric grease on all of the connections, EXCEPT the bulb to ballast connection. All others, put some in there. It will keep the water out, and keep corrosion out.
H
hemi_hawk
do i need just one of these or do i need one for each side, also do these do both high and low beam ?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Just one per kit.
Do you have 2 HID kits? If so, you'll need 2. BUT, by default it is set as the H11 setup. I can order it direct and shoot you an invoice - as there is no option to buy the harness with the 9005 plug on the website.
H
hemi_hawk
not sure what you mean by two kits. i have a ballast for each bulb ( 4 bulbs, 2 high beam 2 low beam ) so i dont know if i need a harness to the lows and a harness for the highs or what
quietpeen
2021 TRX
Hellcat
well son of a *****, i did not do this and i really don't want to take the farking things back out :emotions122:
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
You have 2 kits. :D
You'll need 2 harnesses. $55 shipped for the 2. Shoot me an email - [email protected] and I'll get an invoice over to ya! :birgits_tiredcoffee
errrrrr..........that was the first thing in the PDF instructions. LOL - I need to redo my instructions...........nobody reads that file.
H
hemi_hawk
well slow up... it will be about 4 weeks before i can get them so.....
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
no problem, I'll be here when you are ready.
blackout11
alpharetts GA
2011 R/T
Oh on a good note if you do the fog they are just plug and play lol ask me just do fogs and lows and youll never need high beams again. But welcome to the world of ram trucks where plug and play hid's headlights are not an option :p
