Y Pipe again !!!! UPDATE
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
UPDATE
2015 RAM 1500 Pentastar !
89k on the clock
The flange stud on the Y Pipe flange rusted in 1/2 again!
Past few mornings it had that exhaust leak sound, ,
Same place as a few years ago !
The studs are welded to 1 flange instead of a nut and bolt!
Hope my mechanic can drill the stud out! I do live in the rust belt
Or maybe drill out the studs on the new Y Pipe and put in Grade 8 nuts and bolt
Anyone else have this happen , and yes a bummer lol
PoMansRam
East Aurora NY
Ugh.. I didn't own my 2017 pentastar powered Ram long enough for it to happen, but the flanges on my 2019 classic w/ hemi are pretty crusty with 60k miles on the clock.
I had to replace the whole cat-back exhaust on our 2015 Nissan versa last year because two flanges rotted right off.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Yea this sucks lol Twice since 2016
turkeybird56
Central Texas
Sir, the privilege's you have and enjoy living in an alleged "rust bucket" area.
FWIW, when I was stationed in NY, I always went to car wash every couple of weeks when they were not froze and sprayed off as much of the undercarriage of my Olds that I could. OLDS was from TX, not coated.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Same here I hit the car wash every couple weeks. My 2011 HHR a low end car has only 1 rust bubble under the paint ! My mechanic can not believe how nice it is under there ! My RAM sound a bit like a car with a fart can on it lol
blackbetty14
CT
Hemi 5.7 VVT/Etorque
If you can get the specs on the stud ( thread, DIA and Length you should tap (after drilling) and install a stainless stud (preferably ARP) which are stronger than grade 8 and won’t rust like ever. I try to use them when I can and money allows it. When I did shorties I did them on the collectors as well and the nut was rusted less than 6 months (came with the headers) but the bolt (ARP SS) just changed color.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks
Ill look into those ,, I see no reason why the old stud is welded in place when a Nut and bolt would be a simple fix. But then they would make less $$$ lol
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
UPDATE
Y Pipe now fixed with a new nut and bolt,
All 4 drilled out same time !
Now my RAM does not sound like it has a FART Can on it lol
