Can't say for sure about the OD gears between the Wrangler and the Ram but daughter has a 2016 Wrangler with 35's and had 4.88's put in and now she can't drive it to work. I told her 4.56 was the absolute steepest I would go and that was even pushing it. Now on the highway her engine is cranking. She bought a Superchips to re-calibrate her speedometer but it is over 3000 RPM at over about 55 or so. I think she said it's over 4000 RPM on the highway. I have only driven it a few times since she did all this so my numbers are by memory based on what she told me but it is basically undriveable unless under 40 MPH. She is talking about going to 37's to help a little.I told her 4.56's at the most but the shop she bought everything at talked her into 4.88's and she regrets not listening to me now.
I know I would never want 4.88's in my truck with my stock tires and I never plan to go with taller tires. 4.56's MIGHT be ok but I don't need them for what I tow. If you plan to swap gears use a gear calculator and factor in what type of driving you will be doing. My daughter used to work 3 miles from her house so even with 4.88's her Jeep was fine but she changed jobs and not drives on the highway about 70 miles a day. She ended up buying a car and the Jeep sits in the garage collecting dust now.
A little more than dust here but this is it. Looks great.
And what I tow
