- Joined
- Apr 28, 2012
- Posts
- 27,514
- Reaction score
- 57,691
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Stick with PUP, and think about poor man's redline lubegard biotech. For 6 bucks, it has a lot of the same stuff in redline, here is a thread. Hemi tick or not, our hemi's are starved at idle, it doesn't hurt to get some ep additives between that lifter and cam lob.
You could open the spreadsheet, do an ALT+Print Screen and then paste into the Reply text field.If I could figure out a way to attach a spreadsheet in this forum, I could show summary test data of relative lubricity (film strength) of various motor oils, for directional use.
Now if I could just fix the rear howl.......
RedLine Heavy Shockproof...toss in a quart or two when you put new gear oil in. Worked for me.
What is this RP filter you speak of
Shoutout to Burla and supporting members for spending time with me to understand hemi engine valve lifter failures and best response to mitigate.
As a result and after much study, I am switching from PUP 0W-40 to Red Line 5W-30 @ next oil change in the spring (@ 5k OCI). I'm doing so now to minimize probability of lifter failures, not wait until or unless it occurs. Repair of $4,500 and loss of vehicle during, with same design replacement is unacceptable to me. Even more so on a $50k vehicle.
The value of this site to me led me to become a Supporting Member. Thank you again.
For those interested, I'm summarizing my findings below in bullet form. Stop reading here if uninterested. Feel free to comment or PM me if you would like more detail.
My truck: Ram 2500 HD Crew Cab, 6.4L HEMI, 36k miles.
Location: Central Minnesota (ambients from -30F to +100F)
Application: Mostly dead-heading, some bed loads, sporadic towing with 6,000 lb trailer loads, in hilly driftless midwest region.
FCA Oil Recommended: Pennzoil Ultra Platinum 0W-40
Optimized Oil Study: Red Line 5W-30
Reference Ram 1500 5.7L HEMI FCA Oil Recommended: Pennzoil Ultra Platinum 5W-20
Reasons to switch oil:
- Forum Member experiences with Red Line quieting valve lifter tick, no reported failures known.
- FCA Oil recommendation started with SRT Hemi in Car Applications - trucks were added later.
- SRT is completely different application - supercharged, high rev, high horsepower, racing.
- 40 wt oils are used in highly loaded, high revving, or charged (turbo or super chargers) application, not low rev, naturally aspirated truck engines.
- Red Line 5W-30 is a high 30 wt....closer to low 40 wt
- Hemi 5.7 in half ton truck recommended oil is only 5W-20, 20 wt likely for US CAFE fuel economy sales standards - 30 wt is optimal. This provides directional input for all truck applications.
- 0W oils have 50% higher volatility and generally lower HTHS film strength, also shear down easier.
- 5W provides sufficient cold ambient temp flow for most cold climates - needed only on startup with trucks left outside all night, as in pipelines / rail workers in Canada.
- Red Line oils are polyol ester base stocks (jet oils) that are polar molecules - they adhere to metallic surfaces, unlike PAO synthetics. This "plating-out" is thought to provide better lubrication for the lightly lubricated HEMI valve lifters.
- Polyol Ester base stocks also have high film strength, and even lower volatility than PAO base stocks. Should leave engine parts with minimal deposits and retained oil flow (important for the sensitive valve lifters in HEMI's).
- Polyol Esters are slightly more expensive PAO oils, but I don't drive that many miles anymore (retired), so plan to continue 5k OCI, expense is not major. Amazon has best price for $10.75 per quart in a box of 12 quarts (as of last night).
- Warranty....lots of arguments here. As long as oil is rated SN, Dealers do not have legal right to deny warranty coverage of failure. Reports of them doing so anyway abound, knowing a lawsuit is costly and time-consuming. I'm willing to accept this risk for prevention purposes.
AmazonWhere is everyone getting their Lubegard Bio/Tech?
