That makes sense. I was surprised mine were at 95 when I purchased. They probably went up from 90 sitting on the hot asphalt.They come from the manufacturer with high pressure to keep from getting flat spots. Then, whichever green monkey in service performs the PDI never adjusts the pressure down to door placard levels.
Just a habit to take a tire pressure gauge with me to the dealer when buying a new truck.
Got the same high tire pressure on my 2021 limited. Changed to the door sticker 65-70 and the ride is better but it was still a very stiff ride. After about 3000 miles I'd say its getting better. First 3/4 ton and what a difference from a 1/2 ton Tundra.Also, those pressures were set with cold tires. After driving it home I'm sure your pressures increased from the heat.
But yeah, I run about 73 in my rears and 65 in the fronts. Rides much better. Go too low and the low pressure light will come on.
Insist they refund you your PDI fee. Having to give money back is the surest way to make them learn to do it right.I wish I read this thread before I picked up my new 21 Big Horn in Idaho at DS. Drove it 165 miles home and thought I was gonna loose control of it a few times. I was regretting moving up to a 3/4 ton because of the harsh ride. Next morning I had the bright idea to check the tire pressure. All of them were set at 92 to 93 lbs!!!!! I was pretty PO'd and called the salesman and got the standard, "Oh my, I will look into it" response with no follow up. Dropped the pressure to the door sticker #'s and ride is a lot better. Next vehicle I buy, I'm bringing a tire pressure gauge with me. Sounds like this is a common missed step in the PDI by the dealer.
