Ed Wade
Hello all, I’m new to the forum. Thought I would share my fluid change story with you, some might want to do the same. After much debate I decided to pull the trigger on changing the fluid in my 2014 Hemi Ram 1500. I watched many videos of pan and fluid change, but have never seen just a fluid change. I could not get a definitive answer on the drainbolt being reusable so I decided not to chance it. I brought the trans temp up to 90* then pulled the upper filler plug. 1 quart of fluid came out on it’s own. I then used a fluid extractor to pull another 2.5 quarts and emptied the pan. I then used a cheap fluid pump and pumped 2.5 qts of fresh Maxlife ATF into the fill hole until it started to weap out. I then started the truck with the remote and pumped the other 1 qt in. 3.5 quarts out/3.5 quarts in. I tightened the fill bolt and turned the truck off. I will complete another fluid change when I change my oil this week. Do NOT believe the “lifetime” claim! My truck has 80k easy miles and the fluid was very dark. It’s only been a week, but the trans seems very happy.
Ed
Ed
