PARay
So I leveled my truck a few months ago using Bilsteins set at 2.8" and a 1 inch TGC spacer in the rear, so now the front sits at 40" to the top center of the wheel well and 41" at the rear. I do like having the little bit of rake. But of course since I've been modding, I want to go higher. I'm looking at the Zone 6" /5" rear spring kit, but want to keep my front Bils. I've been reading and seeing people run them at 1.4, 2.1, and 2.8 with this lift and with varying rear spacers. I'm having a hard time wrapping my head around the math on the new height with the added lift. Could I leave my Bils at 2.8" and just adjust with a new coil spacer? Or should I drop the height down a bit? Also, I would be leaving out the pre-load spacer on the kit right? I'm having a shop install my lift and want to make sure I have all this right. I can adjust the Bils myself, but I figure if they will do it during the install then why not have them do it.
