Mike Townsend
OK, I have a strange problem. I got my truck used and the headlights were trashed. I looked around and ended up buying the VIPMoto lights to match the factory projectors. Looked good and I just left the bulbs in that they came with while I looked for better bulbs. I put LED's in the fog lights and they are all kinds of bright.
I go to put the DDM HID 35w kit in the low beams. They do match the color of the fog lights but they are not bright at all. When I went to put them in I noticed that the stupid headlights don't even have the factory snap in bracket for the bulbs to twist into on the low beams. Not sure why since the high beams are normal. So to make these work I cut the strange factory plug and put the correct plug in using the cables I got from O'Reilly's. I drove it for the first time at night last night and they suck so bad.
I don't understand why/how they are so dim. I did have to rig up the clip that holds them in since it doesn't match the factory twist locks. they are sealed so I don't think that is causing the problem.
Any help would be awesome.
