Vent seems to be in order. No grooves that I'm able to discern. It's just starting to leak. I *hate* fluid leaks so I'm going to be babysitting this one and see if it starts to progress.Not as far as I know. Is it seal or does the input shaft have a little groove worn in it?
Also check your t case vent, you'll blow seals if it's plugged off.
It's not leaving fluid on the ground, nor on the undercarriage, so I'll continue to monitor it. When it degrades enough to be an issue, I'll address it then. Thanks for your commentary.thats a rather stupid idea to babysit it when you just put a new one in 20min. or less
