2020 RAM 1500 Headlight Conversion to LED
RodneyS
I have converted my Fog High and Low beam lights to LED. And I am having some problems. The passenger side low beam works sometime but not all the time. I have switched bulbs and it is not the bulb. I also on occasion had the high beam go off and will not come back on unless you restart the truck. Does anyone know if I need to us the OBD to change the lighting type in the system?
Thank you
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
Use alpha OBD would be the smartest thing but you may also need to run a set of canbus modules on the lights even if they say they are built in. Sounds like you just have a very picky truck very sensitive to the voltage limits.
