Gen. 1 Cummins brake pedal wont bounce back- brake lights remain on
JDWF
New England, ND
239 cu. in., 5.9 Cummins, 5.7 Hemi
I can't find the problem. The brake pedal works for braking but wont bounce back to disengage the brake lights. I need to put a tall bottle under the brake to shut them off. Also the clip on the gas pedal that hold the throttle cable broke off and I can't find a similar one anywhere. Finally has anyone found a replacement for the e-brake regulator on the frame?
Thanks
