Help with 5 digit pin
Woodjohn84
Odessa tx
I am needing to get keys programmed for my 2500 ram 6.4 and the lock smith says his deal is asking for a 5 digit pin and told me I need to go to the dealership and get the pin. Well the dealership says all they can pull up is a 4 digit pin. Anybody know anything about this. I have called a bunch of different dealer service departments and they told me the same thing. Any help is greatly appreciated.
W
Woodjohn84
Odessa tx
Thanks. That’s what the dealership is telling me but this locksmith guy saying I need a 5 digit pin
Stick
Just curious, but did they give you the 4-digit PIN without any issues? I've heard some dealers don't want to release it.
Razzman
NorCal
2020 Limited CCSB
I just had a new fob programmed at a locksmith as the wife lost hers :rolleyes: He didn't need a pin at all to do it, connected up under the dash where the security cable plugs in, activated his device and pushed a few buttons. Done. Now hoping she doesn't lose this one.
Guitar Guy
South Carolina
What you have is a "rolling code 5-digit pin system". My dealership never heard of this either. I'm trying to change my RF Hub settings to install RKE in my 2023 Ram 1500 Classic using AlfaOBD and that setting is requiring a 5-digit pin system. Only thing I have found so far is one source said the Autel MaxiIM IM508 "might" be able to provide this. AlfaOBD has a feature to find the code, but says "not supported yet".
My next step is I'm going to contact AlphaOBD and see if they have a workaround for this yet.
chri5k
USA
Diesel
Nice to see a YouTuber that doesn’t take 30 minutes to tell you 3 minutes of information.
dickster63
Howell
6.7 cummins
Using an alpha OBD to access PIN code and it is requiring a five-digit rolling pin.. has anybody been able to figure this out? Attempting to reprogram new key fobs and turn on the remote start on the diesel feature.
dickster63
Howell
6.7 cummins
My next step is I'm going to contact AlphaOBD and see if they have a workaround for this yet...
Trying to program two key fobs to update my 22 ram 2500 so I can turn on the remote start mine also is asking for a five digit rolling pin interested in any updates that you have found out regarding this rolling five pin issue... I am also using the alfa OBD
Jimmy07
Alfaobd can’t do it on your truck. Use JScan instead.
