Is this thing speed governed?
aatk
USA
Ran out of steam at 104 indicated. Didn’t feel like it was power, felt like it’s governed.
Felt just like one of those crappy rentals from the 90s that used to be governed to 85.
Can it be turned off easily?
crazykid1994
Most likely. Same with 4th gens. Speed governed to 105. Usually due to tire ratings. If you check your tires they’re rated for such speed and they’ll limit your vehicle so you don’t go and blow your tires off. Need to get a tune to turn it off but that voids your warranty as you’ll need a new pcm to do that.
Firebird
2019 Ram 2500
Yes they are
JoeCo
NY
Yeah I think most cars are governed and have been since the 90's, I remember back then GM's were governed at 98 for trucks/suvs, 108 for their cars and higher for the performance cars. As was mentioned you can eliminate this but it's probably not worth the trouble/cost unless you want to tune it for other reasons.
turkeybird56
Central Texas
They all are. I topped at 107, but alas, that fast enuf for me. If I wanna go faster. my Honda Wing will scream, LMAO
R
Rogues Gambit
Guest
Limited since the tires aren't designed for triple digits
Elkman
Monterey
V6
Kind of funny in some respects. My Mercedes coupe has limited in the USA to 105 mph but per the law I had to buy expensive tires rated for 140 mph continuous running.
Fatbob Frank
Mc Gregor, Iowa
6.4L
I noticed that as well and assumed it was due to tire restrictions.
It gets up to 100 faster than any pick up I've ever owned and most of my cars as well, but then it just hangs there with a mile of tach left...
madtrucker2016
New York
Well just hope the air bags works on all your trucks what is the purpose of doing such a high rate of speed. Really its a truck not a race car
McBroom
Denison Tx
Hemi 6.4L
What law and where? No law I’m aware of that can dictate what tire you must buy.
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
2012FlameRed1500
Atlanta
When i finally got HP Tuners last year and was able to check the tune on mine, it was limited to 106 mph. Not that i would need to go any faster than that..but i removed it anyway:driver:
nwsewell
US
2019 Classic
My 19 classic is governed around 105-106. Looked up the speed rating on the factory tires, they're only rated "R" for 106mph. Thats probably the reason for the limiter. I'm gonna burn through these tires as fast as I can, so I can justify getting some with a higher speed rating around the time i get my tune. Preferably a "H" or "V" speed rating. Not that it's necessary, or that I would ever find it necessary to go that fast; I just like to know that I could if I needed to.
Sent from my VS996 using Tapatalk
turkeybird56
Central Texas
I love my truck!
Law of Common Sense, LOL
