Low Beam HID Conversion Kit for 2013-2019 Dodge Ram 1500/2500/3500 With projector Headlights
Underground Lighting
Preferred Vendor
Looking to upgrade your Ram Headlights? Need something brighter to see at night? We'll you're in luck. We know the the Ram's factory headlights Suck for visibility! Here is the best solution for visibility.
We are pleased to offer a plug and play, error and flicker free HID Kit. No relays or add-ons needed. This is a simple upgrade by adding a new bulb and a ballast!
Low Beam Kit for 2013-2015 Dodge Ram 1500/2500/3500 With projector Headlights:
2013-2015 Ram Canbus HID Kit
Low Beam Kit for 2016-2019 Dodge Ram 1500/2500/3500 With projector Headlights:
2016-2019 Ram Canbus HID Kit
Only one modifications needed.
1) A simple 7/8" hole to the cover behind the headlight which the kit comes with a grommet to seal!
This modifications will be required for any HID upgrade you go with.
What makes Our Kit Special and better than the rest?
Our kit is a true 35W kit (where as other brands state 35W but are really about 26w) designed to work with computers in the car. The canbus function is high-end with a very fast read and response time to communicate with the car correctly, insuring there will be no error code or flickering issues. Our kit does not use relays or add-ons, it is truly plug and play.
41873101_10212783963256428_8685101893229215744_o.jpg 23518945_1992098537737389_4037355838091961334_n.jpg 37609832_1390573497710266_6236901866572087296_n.jpg View attachment 159584 B50B54A3-E21E-4F01-91B9-B0CC90681BD1.JPG
