2020Ram3500
I have a 2020 Ram 3500. It’s a Laramie. It has the memory seat position. It reset itself (or so I thought) so I programmed it again to the position and the key. It acknowledged it on the gauge cluster that it saved the seat position and paired that key to the #1 position. So I tried to use it and it doesn’t move the seat when you press the button even with the engine running, the key doesn’t move the seat, I locked it walked away and came back and unlocked it and the seat stayed in the same spot. Is this a common problem?
